Появился CBROM 1.15 от Asus (32 Bit Windows). Выковырнут из AsusUpdate V71203 с помощью ResThief.
rapidshare.com/files/65999336/Asus_CBROM32_115.ZIP
CBROM32 V1.15 [Oct 3 2007 Release] (C)ASUSTeK Computer Inc. 2007 cbrom32 InputFile [/other] [8000:0] [RomFile|Release|Extract] cbrom32 InputFile [/D|logo|vga....] [RomFile|Release|Extract] InputFile : System BIOS to be added with Option ROMs /D : For display all combined ROMs informations in BIOS /epa|epa1-7 : Add EPA LOGO BitMap to System BIOS /logo|logo1-7: Add OEM LOGO BitMap to System BIOS /osb_logo|osb_logo1-7: Add OSB LOGO BitMap to System BIOS /osb_bmp|osb_bmp1-7: Add OSB CPU BitMap to System BIOS /oem0-7 : Add special OEM ROM to System BIOS /err : Return error code after executed /btvga : Add VGA ROM to Boot Rom Block Area. /isa : Add ISA BIOS ROM to System BIOS.(/isa Filename [xxxx:0]) /vga, /logo, /pci, /awdflash, /cpucode, /epa, /acpitbl, /vsa, /hpm /hpc, /fnt0 - 5, /ros, /nnoprom, /mib, /group0-5, /NoCompress /jpeg|jpeg1-3: Add JPEG LOGO to System BIOS /rpb : Add RPB ROM to System BIOS /ver : Add version table of source code to System BIOS /jpeg_eng : Add JPEG engine to System BIOS /nc_cpucode : Add non-compress cpu code /srom0-4 : Add software ROM /setup0-1 : Add setup ROM /biosf0-9 : Add BIOS feature ROM /GV3 : Add GV3 ROM /CALS : Calculate ROM Compress size but not add ROM in BIN file /NVMM : Add nVIDIA memory module /MPDRV : Add TPM MP driver /MADRV : Add TPM MA driver /TCGSMI : Add TCG 32bit SMI code /SLPKey : Add SLP 2.0 Public key /SLPMarker : Add SLP 2.0 Marker RomFile : File name of option ROM to add-in noreserve : No reserve system color for BMP logo keepsize : Keep orginal BMP size for Logo Release : Release option ROM in current system BIOS Extract : Extract option ROM to File in current system BIOS <<< Examples >>> cbrom32 6a69s000.bin /D cbrom32 6a69s000.bin /VGA filename cbrom32 6a69s000.bin /VGA filename /ERR
Дрессируем коров![:)](http://bios.rom.by/img/smiles/icon_smile.gif)
Для тех кто будет ковыряться дальше в версии asus update V7.13.01версия cbrom таже 1.15
Подробнее ковыряется фаил winflash.exe ресурс TOOL ---AWDSLP извлекается из файла и удаляется все лишнее до заголовка 4d5a90
Пытаюсь вскрыть BIOS от A7V600 - этот CBROM его не признаёт.
Здесь нашёл - xxsj.net/Mainboard/tools/acbrom.zip
В MyLogo оно явнее видно
оно там тоже в ресурсах в секции TOOL но подписано CBROM.
