Ребят помогите, велючаю ноут а он мне вот это выдаёт
It problem has been detected and windows has been shut down to prevent damage to your computer. A clock interrupt was not received on a secondary processor within the allocated restart your computer. If this screen appears again, follow these steps:
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continue, disable or remove any newly installed hardware or software. Disable bios memory option such as caching or shadowing.
If you need to use safe mode to remove or disable components, restart your computer, press F8 to select Safe Mode.
Technical information: ***STOP: 0*00000101 (0*0000000000000061, 0*0000000000000000, 0*FFFFFA60005EC180, 0*0000000000000001)
Collecting data for crash dump…
Initializing disk for crash dump…
