Computer Setup contains a group of utilities that give you an
overall picture of the computer's hardware configuration and aid
in troubleshooting. These utilities also allow you to set custom
features, such as security options, power conservation levels, and
startup preferences.
1. Turn on or restart the computer by selecting Start - Shut
Down - Restart the computer.
2. Press F10 when the blinking cursor appears near the upperright
corner of the display.
3. Select Computer Setup and press Enter.
4. Select Exit when you are finished running Computer Setup.
A series of Exit options appear.
NOTE: The first time you use the computer, select the language
you need when the Welcome screen appears, and press Enter.
If you enabled a setup password, it must be used to access
Computer Setup
Computer Setup
