Как поглядел, то бивус точно не авард, а
Как поглядел, то бивус точно не авард, а скорее всего какой-то Compaq-овский, так как чудесных слов Award, Ami, или Phoenix не встречал ни в во всяких Benchmark-ах ни в pdf-ке на комп - везде только чудесное словцо COMPAQ.
HWiNFO например пишет:
Bios vendor: Compaq
Bios version: 686T3
Bios start segment: E000
Bios size: 256K
Сами разработчики описывают CMOS так:
Configuration Memory (CMOS) Map
Location Function Location Function
00-0Dh Real-time clock
0Eh Diagnostic status
0Fh System reset code
10h Diskette drive type
11h Reserved
12h Hard drive type
13h Security functions
14h Equipment installed
15h Base memory size, low byte/KB
16h Base memory size, high byte/KB
17h Extended memory, low byte/KB
18h Extended memory, high byte/KB
19h Hard drive 1, primary controller
1Ah Hard drive 2, primary controller
1Bh Hard drive 1, secondary controller
1Ch Hard drive 2, secondary controller
1Dh Enhanced hard drive support
1Eh Reserved
1Fh Power management functions
24h System board ID
25h System architecture data
26h Auxiliary peripheral configuration
27h Speed control external drive
28h Expanded/base mem. size, IRQ12
29h Miscellaneous configuration
2Ah Hard drive timeout
2Bh System inactivity timeout
2Ch Monitor timeout, Num Lock Cntrl
2Dh Additional flags
2Eh-2Fh Checksum of locations 10h-2Dh
30h-31h Total extended memory tested
32h Century
33h Miscellaneous flags set by BIOS
34h International language
35h APM status flags
36h ECC POST test single bit
37h-3Fh Power-on password
40h Miscellaneous Disk Bits
41h-44h Hood Removal Time Stamp
45h Keyboard snoop byte
46h Diskette drive status
47h Last IPL device
48h-4Bh IPL priority
4Ch-4Fh BVC priority
51h ECC DIMM status
52h Board revision (from boot block)
53h SWSMI command
54h SWSMI data
55h APM command
56h Erase-Ease keyboard byte
57h-76H Saved CMOS location 10h-2Fh
77h-7Fh Administrator password
80h ECMOS diagnostic byte
81h-82h Total super ext. memory tested good
83h Microprocessor chip ID
84h Microprocessor chip revision
85h Hood removal status byte
86h Fast boot date
87h Fast boot status byte
8Dh-8Fh POST error logging
90h-91h Total super extended memory configured
92h Miscellaneous configuration byte
93h Miscellaneous PCI features
94h ROM flash/power button status
97h Asset/test prompt byte
9Bh Ultra-33 DMA enable byte
9Ch Mode-2 Configuration
9Dh ESS audio configuration
9Eh ECP DMA configuration
B0h-C3h Custom drive types 65, 66, 68, 15
C7h Serial port 1 address
C8h Serial port 2 address
C9h COM1/COM2 port configuration
DEh-DFh Checksum of locations 90h to DDh
E0h-FFh Client Management error log
Надеюсь что кто-нить подскажет как мне поступать далее, чтобы решить эту проблему. А может кто знает как просто вырубить в этом бивусе
POST error logging, чтоб не давить каждый раз эту нехорошую F1.
Заранее благодарен GhostBest
