3. New Koeffs Support
3. New Koeffs Support : is not needed to be fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.07 (C)Award Software 2000 All Rights Reserv
Adding modul.tmp 25.3%
Adding start.tmp 87.5%
Adding cpucode.bin ... 89.1%
b.bin have not enough space for adding ROM. (Over 189Bh bytes)
ЧТО ДЕЛАТЬ? помогите пожалуйста, а то я только под виндовсом работать могу, а под Досом только пару команд знаю...
