Нескромный вопрос - а к BIOS'у каким боком?
На всякий случай напомню BIOS - Basic Input/Output System, т.е. имеется базовая функциональность, обеспечиваемая BIOS'ом, и расширенная, обеспечиваемая ОС.
А в случае микроконтроллера есть, как правило, только основная функциональность, обеспечиваемая прошивкой. В некоторых случаях можно исполнять код, загружаемый извне, но такой режим поддерживают не все контроллеры.
По самой серии:
The H8S/2140B Series are microcomputers (MCUs) made up of the H8S/2000 CPU employing Hitachi’s original architecture as their cores, and the peripheral functions required to configure a system.
The H8S/2000 CPU has an internal 32-bit configuration, sixteen 16-bit general registers, and a simple and optimized instruction set for high-speed operation. The H8S/2000 CPU can handle a 16-Mbyte linear address space.
This LSI is equipped with a data transfer controller (DTC) as a bus master, ROM, RAM, an 8-bit PWM timer (PWM), a 14-bit PWM timer (PWMX), a 16-bit free-running timer (FRT), an 8-bit timer (TMR), timer connection, a watchdog timer (WDT), a serial communication interface (SCI), a keyboard buffer controller, a host interface X-bus interface (XBS), a host interface LPC interface (LPC), an 8-bit D/A converter, a 10-bit A/D converter, and I/O ports as on-chip peripheral modules required for system configuration. An I2C bus interface (IIC) can also be included as an optional interface.
A high-functionality bus controller is also provided, enabling fast and easy connection of DRAM and other kinds of memory.
A flash memory (F-ZTAT) version is available for this LSI's ROM. This provides flexibility as it can be reprogrammed in no time to cope with all situations from the early stages of mass production to full-scale mass production. This is particularly applicable to application devices with specifications that will most probably change.
Как сливать?
Обычно имеется некое устройство, именуемое программатором.
Утилита для прошивки есть
Эту фразу воспринимать как утверждение или вопрос?
это LPC?
LPC поддерживается, но является ли оно интерфейсом программирования в данном случае - не знаю, надо внимательно читать документацию.
По самой серии:
