Только у нас Вы можете получить этот незабываемый сервис (кое-что урезано по соображениям NDA):
; TABLE USAGE DESCRIPTION: ;
; This table will be programmed into the chipset in the hook ;
; bla-bla-bla init. The registers in this table are the Registers in ;
; the bla-bla Function bla-bla (Bla Bla-bla unit). ;
; Format of each table entry: ;
; 1st byte: Chipset register number. ;
; 2nd byte: Bit Mask of Reserved Bits. Bits set to 1 in ;
; the mask will not be touched by the programming ;
; routine. All other bits will be cleared before ;
; applying OR Mask. ;
; If no reserved bits exist, make the mask = 0 ;
; 3rd byte: OR Mask. This mask will be validated against ;
; the mask of Reserved bits before being ;
; programmed into the chipset. ;
; This data structure is repeated as neccessary. ;
