Читал и перечитывал много раз. The Introduction of BIOS
The Introduction of BIOS BACK Function
Advanced BIOS Back & Recovery Function
“BIOS Back” function is automatically activated when the original BIOS malfunction occurs. When it
occurs to BIOS malfunction, the BIOS BACK function will be activated automatically, then the
system will restart to reload the BIOS backup to the system boot up menu as the following figure. It
takes 4 to 8 seconds to get into the boot up menu and here comes the message, “Warning! Now
System is BACKUP BIOS. Please reflash primary BIOS.” after system reboots. And then, please
follow the OSD to press “F1” button to continue to log on your operation system.
Please make sure to Update the BIOS after getting into operation system, or the BIOS BACK function
will check your primary BIOS status every time, and it may cause your inconvenience too.
единственное что делает BACKUP BIOS это загружается если основной грохнулся.
