Attention! - ASUS BIOS!
Remove "otkat" (backup key)
1. New CPU Support : -> fixed.
2. P3-detect error : not found.
3. New Koeffs Support :> -> fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : -> fixed.
6. "MB"/"GB" string search : -> fixed.
7. 65Gb-problem (1-st step) : -> fixed.
8. 65Gb-problem (2-nd step) : -> fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : -> fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: -> fixed.
Adding timings-tweak.Adding "Turbo RAM"-tweak.
UDMA66/100/13CBROM V2.08 (C)Award Software 2000 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.08 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 30.4%
Adding tweak.tmp 69.5%
Adding cpucode.bin ..... 50.7%
Warning! BootBlock was changed! Flashing BIOS only WITH BootBlock!
(c)2002-2003 apple_rom, www.ROM.by
Если снова не будет сообщения о версии патчера - больного нужно на осмотр...
Отослал...
Вот лог:
Found 2Mbit BIOS (4.5x)!
