lich said, and I am just translating that there is no difference for the patcher is your bios file beta or release one. You may flash the beta one in original state, may be it'll work and there'll be no need for patching, if it'll satisfy you. If it will not - patch & flash the release one.
And about Acorp mobo - it's very likely there is no support for non-standart FSB freq in its bios, so patcher just can't made it open. So you have either to set your CPU running on 100MHz bus (probably it can't due to manufacturing technology limit), or change the mobo.
Or, install something like SoftFSB or CPUFSB and set FSB from Windows. But beware - modern HDDs do not like PCI overclocking and you may lose your data.
2 lich
Переходник, который может выставить 75 или 83 по шине? Первый раз про такое чудо слышу
2 lich
Первый раз про такое чудо слышу ![lol](http://bios.rom.by/img/smiles/icon_lol.gif)
