Вроде есть http://downloadmirror.intel.com/15110/eng/D201GLY2_TechProdSpec.pdf страница 30 Table 8. Wake-up Devices and Events These
Вроде есть
страница 30
These devices/events can wake up the
computer…
…from this state
LAN S1, S4, S5 (Note)
Modem (back panel Serial Port A) S1
PME# signal S1, S4, S5 (Note)
Power switch S1, S4, S5
PS/2 devices S1
RTC alarm S1, S4, S5
USB S1
Note: For LAN and PME# signal, S5 is disabled by default in the BIOS Setup program. Setting this option
to Power On will enable a wake-up event from LAN in the S5 state.
NOTE
The use of these wake-up events from an ACPI state requires an operating system
that provides full ACPI support. In addition, software, drivers, and peripherals must
fully support ACPI wake events.
Кто мешает полностью выключить её удалённо, а потом включить утилиткой для удалённого включения
послать MAGIC PACKET.
вот ещё про Wake
страница 27
1.11 Power Management
Power management is implemented at several levels, including:
• Software support through Advanced Configuration and Power Interface (ACPI)
• Hardware support:
⎯ Power connector
⎯ Fan connectors
⎯ LAN wake capabilities
⎯ Instantly Available PC technology
⎯ Resume on Ring
⎯ Wake from USB
⎯ Wake from PS/2 devices
⎯ Power Management Event signal (PME#) wake-up support
