спаяли программатор прошили результат 0, материнка при включении признаков жизни
спаяли программатор
прошили
результат 0, материнка при включении признаков жизни не подает(вентили крутятся, изображения на мониторе нет, спикер молчит)...
SPI FlashROM Programmer 1.6 (C) 2008-2009 by Martin Rehak;
Compiled by GCC 3.4.6 (Debian 3.4.6-9) at 00:05:00, Jan 22 2009
(GNU/Linux compatability)
root@PartedMagic:/media/sdc1/spipgm# ./SPIPGM
SYNTAX: spipgm /i|r|d|e|p [filename] [address] [size] [/l=iobase] [/d=delay]
        /i - identify SPI FlashROM
        /r address size - read & display data block (0x prefix = hexa number)
        /d filename - dump entire FlashROM to file
        /p filename - program entire FlashROM from file (without erase)
        /e - erase entire FlashROM
        /u - unlock write protection bits (may depend on WP# level)
        /l= LPT port I/O base address (default is 378h - LPT1)
        /d= additional delay for SPI clock pulse width [usec] (default is 0)
LPT to SPI pin assignment (based on BSD AVR programmer):
pin  7 = D5 -> CS#
pin  8 = D6 -> SCK (CLK)
pin  9 = D7 -> MOSI (DIO)
pin 10 = ACK -> MISO (DO)
pin 18 = GND -> GND
root@PartedMagic:/media/sdc1/spipgm# ./SPIPGM /i
SPI connected to LPT port at I/O base address: 378h, SCK pulse width: t+0us
FlashROM JEDEC ID, type: C22014h
Macronix MX25L8005 (1MB)
Status = 00h (SRP, RES, TB , BP2, BP1, BP0, WEL, BSY)
               0    0    0    0    0    0    0    0
root@PartedMagic:/media/sdc1/spipgm# ./SPIPGM /d old.bin
Reading sector at: 000FF000h (100%)
               0    0    0    0    0    0    0    0
root@PartedMagic:/media/sdc1/spipgm# ./SPIPGM /e
Status = 02h, WE bit is enabled
Please wait... done.
root@PartedMagic:/media/sdc1/spipgm# ./SPIPGM /p bios.rom
Programming page at: 000FFF00h (100%)
               0    0    0    0    0    0    0    0
убил биос на asrock
