19:31:45.18: Flash ROM ID: 0000,0000
19:31:45.23: Entering emergency mode
19:31:46.11: Flashing BIOS including BootBlock
19:31:48.91: Flashing 65536b long BIOS image to 0
19:31:51.27: Flashing failed
19:31:51.27: Exiting UniFlash...
19:31:51.27: Turning off logging, shutting down to real mode
Пишет, что поверка не прошла и предлагает попробовать ещё раз
19:33:19.65: UniFlash v1.37 started: C:\UNIFLASH.EXE -pcirom 2 0 0 -force BFD4 -e 1.bin -log
19:33:19.65: Chipset detected: nVidia nForce2
19:33:19.65: Flat Real Mode initialized
19:33:19.70: CMOS size detected: 256b
19:33:20.86: PCI expansion ROM at 02:00:00 selected
19:33:20.86: Allocating memory block 00010000
19:33:20.86: Allocating memory block 00001080
19:33:20.86: Flash ROM chip forced: SST 39xF512 series (3V/2.7V)
19:33:20.86: Flash ROM ID: 0000,0000
19:33:20.86: Entering emergency mode
19:33:21.73: Flashing BIOS including BootBlock
19:33:29.20: Exiting UniFlash...
19:33:29.20: Turning off logging, shutting down to real mode
Тут он пишет Error #100 Disk read error
Затем: Unable to read file! (Атрибуты проверены, да и не в них дело)
Видимо, проблема в ROM ID, попробовал восстановить:
19:35:30.86: UniFlash v1.37 started: C:\UNIFLASH.EXE -pcirom 2 0 0 -force BFD4 -repair -log
19:35:30.86: Chipset detected: nVidia nForce2
19:35:30.86: Flat Real Mode initialized
19:35:30.92: CMOS size detected: 256b
19:35:32.13: PCI expansion ROM at 02:00:00 selected
19:35:32.29: Allocating memory block 00010000
19:35:32.29: Allocating memory block 00001080
19:35:32.29: Flash ROM chip forced: SST 39xF512 series (3V/2.7V)
19:35:32.29: Flash ROM ID: 0000,0000
19:35:32.84: Exiting UniFlash...
19:35:32.84: Turning off logging, shutting down to real mode
Без результата.
Также пробовал Wfflash v5.3 с параметром mn
Load original VGA ROM/Image and save to
Page writing Flash ROM with file 1.bin
Verifying error address 0000 data ff
Try it again (Y)es or (N)o?
Напомню, что у меня MSI FX5200, которой была залита прошивка от FX 5200 Ultra
Маркировка флэшки SST MPF 39VF512 90-4C-NH
Итак, что я пробовал:
Во-первых, скачал новый Uniflash v1.37 и nvflash v5.08
Во-вторых, стал пробовать
(Разумеется , всё под чистым DOS’ом)
nvflash -f 1.bin -5 -6
NVIDIA Flash ROM utility
Version 04.46
Chip name=GeForce FX 5200 Ultra, Vendor ID=10DE, Device ID=0321
Opened 1.bin successfully.
Checking for supported EEPROM...
EEPROM man.ID,devcode (20,FF) : Unknown
ERROR: Supported EEPROM not found
Пробовал два варианта прошивок:
Первый – оригинальный 62k (1.bin), второй – добил первую прошивку FF-ками до 64k (3.bin)
19:31:43.80: UniFlash v1.37 started: C:\UNIFLASH.EXE -pcirom 2 0 0 -force BFD4 -e 3.bin -log
19:31:43.80: Chipset detected: nVidia nForce2
19:31:43.80: Flat Real Mode initialized
19:31:43.86: CMOS size detected: 256b
19:31:45.18: PCI expansion ROM at 02:00:00 selected
19:31:45.18: Allocating memory block 00010000
19:31:45.18: Allocating memory block 00001080
19:31:45.18: Flash ROM chip forced: SST 39xF512 series (3V/2.7V)
Без результата.
