miXel C:\Users\FE66~1 bp-6a9 q12.bin BIOS Patcher ver. 6.00.alpha9.
miXel
C:\Users\FE66~1>bp-6a9 q12.bin
BIOS Patcher ver. 6.00.alpha9. |for Award/Phoenix & AMI bioses|
Found 2Mbit Award BIOS (6.x)!
Found AMD K7-BIOS/platform!
1. New CPU Support : -> fixed.
Adding AMDK7NOW! support : -> fixed.
2. XP frequency : -> fixed.
3. New Koeffs Support : is not needed to be fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: not found.
Tweak options addinng:
Bus Disconnect Support : -> fixed.
Display Features adding : -> fixed.
cbrom.exe V1.82 [04/11/07] (C)Phoenix Technologies 2001-2007
Adding modul.tmp 42.8%
Adding tweak.tmp 45.2%
Adding start.tmp 87.5%
лог правильный?шить можно?
