JTPM1 -- pin 3 --
3 Июл 2014 - 18:35
Сказочник
27403
1742.14
JTPM1 --> pin 3 --> voltage
Help me repair mainboard
2 maco - with some individuals VOM
Do you mean ICH7? It consists of many
I want to ask how to determine south
Volt-Ohm-Milliammeter, for example.
try to rephrase you question, nothing can be
I want to know how the south bridge
thank you very much,so i hope you will
lexuanhoa , a little uncertainties appear here,
I have sent mail to you. email: yeuthichvothuat@gmail.com.
Sorry, I do not have a schematic diagram
Dr.Rer.Nat писал (-а): precision, which is VTT_OUT_LEFT. VTT_OUT_LEFT.
you may guide me up display up community
To VTT_OUT_LEFT. If CPU
commonly, CPU_RST# has a pull-up resistor connection to
I'm currently fixing MSI G41-P28 mainboard series 7592-52.2
So I will take a picture and send
How (at which conditions) and where did you
hardly... Some more moments can be
thank you a lot, you can give me
everything is much simpler, numbers are 1,2,3 part1
thank you very much, I have seen many
Relating to your question about learning materials. There
is this cpu supported by the mainboard? What about
anyone can give me study material mainboard repair,
I checked the source vCore ok! but the
What do you mean "CPU is not working"?
I do not understand the reason why the
What happens than? :) What's the problem? Can you
