коды CRC-16 checking для Award БИОС (v.4.51 с бутблоком):
..... 2000:7085 copy_dcomprssion_result proc near 2000:7085 ; CODE XREF: lzh_expand+42p 2000:7085 50 push ax 2000:7086 53 push bx 2000:7087 52 push dx 2000:7088 51 push cx 2000:7089 06 push es 2000:708A 56 push si 2000:708B A1 04 01 mov ax, ds:104h 2000:708E 8E C0 mov es, ax 2000:7090 assume es:nothing 2000:7090 8B 1E 06 01 mov bx, ds:106h 2000:7094 BE 1C 37 mov si, 371Ch ; ds:si = decompressed buffer 2000:7097 next_byte_2_copy: ; CODE XREF: copy_dcomprssion_result+19j 2000:7097 8A 04 mov al, [si] 2000:7099 26 88 07 mov es:[bx], al 2000:709C 46 inc si 2000:709D 43 inc bx 2000:709E E2 F7 loop next_byte_2_copy 2000:70A0 89 1E 06 01 mov ds:106h, bx 2000:70A4 0B DB or bx, bx 2000:70A6 75 06 jnz not_next_seg 2000:70A8 81 06 04 01 00 10 add word ptr ds:104h, 1000h 2000:70AE not_next_seg: ; CODE XREF: copy_dcomprssion_result+21j 2000:70AE 5E pop si 2000:70AF 07 pop es 2000:70B0 59 pop cx 2000:70B1 3B C1 cmp ax, cx 2000:70B3 72 30 jb exit 2000:70B5 41 inc cx 2000:70B6 BB 1C 37 mov bx, 371Ch 2000:70B9 next_byte: ; CODE XREF: copy_dcomprssion_result+5Ej 2000:70B9 0F B6 07 movzx ax, byte ptr [bx] ; get next byte to calc crc16 2000:70BC 49 dec cx 2000:70BD E3 26 jcxz exit 2000:70BF 50 push ax 2000:70C0 53 push bx 2000:70C1 56 push si 2000:70C2 8B F0 mov si, ax 2000:70C4 A1 0C 03 mov ax, ds:30Ch 2000:70C7 33 C6 xor ax, si ; calc CRC16 value 2000:70C9 25 FF 00 and ax, 0FFh 2000:70CC 8B F0 mov si, ax 2000:70CE D1 E6 shl si, 1 2000:70D0 8B 9C 0C 01 mov bx, [si+10Ch] 2000:70D4 A1 0C 03 mov ax, ds:30Ch 2000:70D7 C1 E8 08 shr ax, 8 2000:70DA 33 C3 xor ax, bx 2000:70DC A3 0C 03 mov ds:30Ch, ax 2000:70DF 5E pop si 2000:70E0 5B pop bx 2000:70E1 58 pop ax 2000:70E2 43 inc bx 2000:70E3 EB D4 jmp short next_byte 2000:70E5 ; --------------------------------------------------------------------------- 2000:70E5 exit: ; CODE XREF: copy_dcomprssion_result+2Ej 2000:70E5 ; copy_dcomprssion_result+38j 2000:70E5 5A pop dx 2000:70E6 5B pop bx 2000:70E7 58 pop ax 2000:70E8 C3 retn 2000:70E8 copy_dcomprssion_result endp ; ..... 2000:790B --- Make_CRC16_Table --- 2000:790B 1st pass, the base address for DS is 3_0000h 2000:790B in: ds = scratch_pad_segment for CRC table 2000:790B out: ds:10Ch - ds:11Bh = CRC-16 table 2000:790B ; --------------- S U B R O U T I N E --------------------------------------- 2000:790B Make_CRC16_Table proc near ; CODE XREF: decomprssion_ngine+ECp 2000:790B 51 push cx 2000:790C 53 push bx 2000:790D 50 push ax 2000:790E 56 push si 2000:790F BE 0C 01 mov si, 10Ch 2000:7912 B9 00 01 mov cx, 100h 2000:7915 next_byte: ; CODE XREF: Make_CRC16_Table+2Bj 2000:7915 B8 00 01 mov ax, 100h 2000:7918 2B C1 sub ax, cx 2000:791A 50 push ax 2000:791B BB 00 00 mov bx, 0 2000:791E next_bit: ; CODE XREF: Make_CRC16_Table+25j 2000:791E A9 01 00 test ax, 1 2000:7921 74 07 jz LSB_is_0 2000:7923 D1 E8 shr ax, 1 2000:7925 35 01 A0 xor ax, 0A001h ; "CRC-substract" with the poly (the poly is A001h) 2000:7928 EB 02 jmp short write_tmp_crc_val 2000:792A ; --------------------------------------------------------------------------- 2000:792A LSB_is_0: ; CODE XREF: Make_CRC16_Table+16j 2000:792A D1 E8 shr ax, 1 2000:792C write_tmp_crc_val: ; CODE XREF: Make_CRC16_Table+1Dj 2000:792C 43 inc bx 2000:792D 83 FB 08 cmp bx, 8 2000:7930 72 EC jb next_bit 2000:7932 5B pop bx 2000:7933 89 00 mov [bx+si], ax ; 1st pass: 2000:7933 ; mov ds:[bx+si], ax <=> mov 3000:[bx+si], ax 2000:7935 46 inc si 2000:7936 E2 DD loop next_byte 2000:7938 5E pop si 2000:7939 58 pop ax 2000:793A 5B pop bx 2000:793B 59 pop cx 2000:793C C3 retn 2000:793C Make_CRC16_Table endp .... 2000:793D --- Calc_LZH_hdr_CRC16 --- 2000:793D in: ds:571Ch = LZH_hdr_len 2000:793D ds:102h = LZH_hdr_byte_index 2000:793D ds:10Ch - ds:30Bh = CRC16 table 2000:793D 2000:793D out: ds:30Ch = LZH_hdr CRC16 calculated value 2000:793D ds:314h = size of LZH_hdr saved to ram in byte 2000:793D ; --------------- S U B R O U T I N E --------------------------------------- 2000:793D Calc_LZH_hdr_CRC16 proc near ; CODE XREF: ReadHeader+2Cp 2000:793D 50 push ax 2000:793E 53 push bx 2000:793F 51 push cx 2000:7940 52 push dx 2000:7941 0F B6 0E 1C 57 movzx cx, byte ptr ds:571Ch ; cx = LZH_hdr_len 2000:7946 06 push es 2000:7947 56 push si 2000:7948 8B 1E 02 01 mov bx, ds:102h ; 1st pass, bx = LZH_hdr_byte_index (2) 2000:7948 ; i.e. after hdr_len and 8-bit chksum 2000:794C BE 00 00 mov si, 0 2000:794F next_byte: ; CODE XREF: Calc_LZH_hdr_CRC16+19j 2000:794F E8 79 01 call FetchByte 2000:7952 88 04 mov [si], al ; save LZH_hdr byte at ds:[si], i.e. 1st pass 3000:[si] 2000:7954 43 inc bx 2000:7955 46 inc si 2000:7956 E2 F7 loop next_byte ; loop until last LZH hdr byte 2000:7958 8B C3 mov ax, bx 2000:795A 2B 06 02 01 sub ax, ds:102h ; ax = real_LZH_hdr_len (not including the first two ID bytes) 2000:795E 89 1E 02 01 mov ds:102h, bx ; ds:102h = index_to_byte_after_LZH_hdr 2000:7962 5E pop si 2000:7963 07 pop es 2000:7964 A2 1C 57 mov ds:571Ch, al ; ds:571Ch = real_LZH_hdr_len (not including the first two ID bytes) 2000:7967 8B C8 mov cx, ax ; cx = ax = real hdr len 2000:7969 01 06 14 03 add ds:314h, ax ; ds:314h = total size of LZH_hdr saved to ram (in byte)? 2000:796D 41 inc cx 2000:796E BB 00 00 mov bx, 0 2000:7971 _next_byte: ; CODE XREF: Calc_LZH_hdr_CRC16+5Ej 2000:7971 0F B6 07 movzx ax, byte ptr [bx] 2000:7974 49 dec cx 2000:7975 E3 26 jcxz exit 2000:7977 50 push ax 2000:7978 53 push bx 2000:7979 56 push si 2000:797A 8B F0 mov si, ax ; si = LZH_hdr_byte 2000:797C A1 0C 03 mov ax, ds:30Ch ; mov ax, tmp_CRC_16_calculation_result; 2000:797C ; ds:30Ch = tmp_CRC_16_calculation_result 2000:797F 33 C6 xor ax, si ; calculate 16-bit CRC of the LZH header 2000:7981 25 FF 00 and ax, 0FFh 2000:7984 8B F0 mov si, ax 2000:7986 D1 E6 shl si, 1 2000:7988 8B 9C 0C 01 mov bx, [si+10Ch] ; mov bx, CRC_16_table[si] 2000:798C A1 0C 03 mov ax, ds:30Ch 2000:798F C1 E8 08 shr ax, 8 2000:7992 33 C3 xor ax, bx ; calculate 16-bit CRC of the LZH header 2000:7994 A3 0C 03 mov ds:30Ch, ax ; mov tmp_CRC_16_calculation_result, ax ; 2000:7994 ; ds:30Ch = tmp_CRC_16_calculation_result 2000:7997 5E pop si 2000:7998 5B pop bx 2000:7999 58 pop ax 2000:799A 43 inc bx 2000:799B EB D4 jmp short _next_byte 2000:799D ; --------------------------------------------------------------------------- 2000:799D exit: ; CODE XREF: Calc_LZH_hdr_CRC16+38j 2000:799D 5A pop dx 2000:799E 59 pop cx 2000:799F 5B pop bx 2000:79A0 58 pop ax 2000:79A1 C3 retn 2000:79A1 Calc_LZH_hdr_CRC16 endp ........
... greetz Pinczakko
Немного подкорректировал грамматику, если ты не против - ivp
... greetz Pinczakko![wink](http://bios.rom.by/img/smiles/icon_wink.gif)
- ivp
