Итак вот лог патчера: bp v0103_9a.bin /c
bp v0103_9a.bin /c >report.txt
BIOS Patcher ver. 4.23.
Found 2Mbit BIOS (6.x)!
Enter CPU Name: (max - 32, recomended - 8-24 symbols)
Intel(R) Pentium(R) CPU 2.40GHz
Found Pentium4-BIOS/platform!
1. New CPU Support           : not found.
Unlock Hyper-Trhreading Select for all CPUs
3. New Koeffs Support        : is not needed to be fixed.
4. 32Gb-problem              : not found.
5. Some HDD detect-problem   : not found.
6. "MB"/"GB" string search   : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x  : not found.
11.New Stepping Support      : is not needed to be fixed.
12.Tualatin L2-init error    : not found.
13.New Freq in Setup open    : found, but Unknown format!
14.Set "Y" as default on exit: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp  18.1%
Adding start.tmp  87.5%
Adding cpucode.bin  98.8%
(c)2002-2003 apple_rom, www.ROM.by
Значит ли это что бинарник готов? Шить его в мать?
Проц не меняет имя!
