The last category of boards are those which need hardware modification to have a PCI clock of 33Mhz together with 133Mhz FSB. They have clock chips with 4 frequency selection inputs (such as ics9250-08), but only 3 of them are wired on the board. At least P2B-L/S/LS rev. 1.04 D03, P2B-D/DS rev. 1.06 D03 and some early revision P2B-f belong to that category. They will all run the pci clock at 44Mhz if you chose 133Mhz FSB - you're very likely to get trouble, as a lot of devices won't work at that clock frequency.
rgt
homepage.hispeed.ch/rscheidegger/p2b_procupgrade_faq.html
это, так сказать, документальное свидетельство того, что мне это не померещилось.
Вещественное док-во #2
msg.asus.com.tw/mbmm/PCBA/Intel/BX/P2B-F.XLS
т.е. разных версий ревизий 1.00 было много, в т.ч. и с указанной проблемой....
