Хоть это и асус, но патчер его берет , по крайне мере согласно логу
Прошивку пропатчил, скачанную с оф.сайта
Лог
BIOS Patcher ver. 4.23.
Found 2Mbit BIOS (4.5x)!
Attention! - ASUS BIOS!
Enter CPU Name: (max - 32, recomended - 8-24 symbols)
1. New CPU Support : -> fixed.
2. P3-detect error : not found.
3. New Koeffs Support :> -> fixed.
4. 32Gb-problem : -> fixed.
5. Some HDD detect-problem : -> fixed.
6. "MB"/"GB" string search : -> fixed.
7. 65Gb-problem (1-st step) : -> fixed.
8. 65Gb-problem (2-nd step) : -> fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : -> fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: -> fixed.
UDMA for "big"-HDD on UDMA33_only_MB fix: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 30.7%
Adding cpucode.bin 50.7%
Warning! BootBlock was changed! Flashing BIOS only WITH BootBlock!
(c)2002-2003 apple_rom, www.ROM.by
Дерзайте! О результатах сообщите
ЗЫ в двух местах постить необязательно
Лог
BIOS Patcher ver. 4.23. Attention! Advanced qualification is required!
Attention! - ASUS BIOS!![;)](http://bios.rom.by/img/smiles/icon_wink.gif)
[/](c)2002-2003 apple_rom, www.ROM.by Дерзайте! О результатах сообщите
