которая в середине работы визжа-надрываясь и моргая всем, чем только можно, ругается ошибкой "1000-0146" в ходе "DTS Short Test"
-DTS or DST ? (dst=drive self test)
5.2.6 Seagate Drive Self Test (DST)
Drive Self Test (DST) is a technology designed to recognize drive fault conditions that qualify the drive as a
failed unit. DST validates the functionality of the drive at a system level.
There are two test coverage options implemented in DST:
1. Extended test
2. Short test
The most thorough option is the extended test that performs various tests on the drive and scans every logical
block address (LBA) of the drive. The short test is time-restricted and limited in length—it does not scan the
entire media surface, but does some fundamental tests and scans portions of the media.
If DST encounters an error during either of these tests, it reports a fault condition. If the drive fails the test,
remove it from service and return it to Seagate for service.
5.2.6.1 DST failure definition
The drive will present a “diagnostic failed” condition through the self-tests results value of the diagnostic log
page if a functional failure is encountered during DST. The channel and servo parameters are not modified to
test the drive more stringently, and the number of retries are not reduced. All retries and recovery processes
are enabled during the test. If data is recoverable, no failure condition will be reported regardless of the number
of retries required to recover the data.
The following conditions are considered DST failure conditions:
• Seek error after retries are exhausted
• Track-follow error after retries are exhausted
• Read error after retries are exhausted
• Write error after retries are exhausted
Recovered errors will not be reported as diagnostic failures...
каким образом ето влияет на зарядку -я понятия не имею, однако не стоит забывать что мы имеем дело с БРАНД НЕЙМ-ом.
если ето действително хард влияет на все ети проблемы то можно его потестить спецальными тулзами, что бы точно знать ,что ето не в нем дело.На худой конец, если не хочетса тестит драив то просто его вытащить и попробовать зарядить без него (знаю что звучит очень странно но все же)
Добавлено спустя 15 минут 9 секунд:
This message indicates that the AC adapter being used by the system may not be detected correctly. This can usually be fixed by updating the system BIOS.
-ето был ответ одного из модераторов делл форума (более 6500 постов)
Покури ети посты может найдеш что то полезное, не знаю что идумать проблема ,такое ощущение , решаетса настолько по разному и затрагивает столько компонентов которые поидее никаким образом не должны влиять на ее решение...:
и все напомню - пользуйтесь поиском
1. Extended test
2. Short test
google.com/search?hl=en&lr=&q=1000-0146&btnG=Search
forums.us.dell.com/supportforums/search?board_id=latit_power&submitted...
Добавлено спустя 1 день 12 часов 6 минут 46 секунд:
рекомендую спосить ТУТ - шансы больше чем тут.
