http://www.rom.by/phpBB2/viewtopic.php?t=12068 http://www.google.com/search?hl=en q=how+to+enter+in+to+BIOS+on+COMPAQ Рекомендую почитать главу
google.com/search?hl=en&q=how+to+enter+in+to+BIOS+on+COMPAQ
Рекомендую почитать главу 13 в след документе,особенно полезно будет если никак не воити в биос сетуп:
h20000.www2.hp.com/bc/docs/support/UCR/SupportManual/TPM_316216-003_rev3_u... ~6MB
а вообше вам нужен SYSTEM РОМПАQ tyt :
h18007.www1.hp.com/support/files/Armada/us/locate/4_1087.html
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Compaq: (F10) (do this when the cursor is in the upper right corner of the screen blinking)
Dell: - F1 or Del.
Dell: - Some require pressing reset twice
Dell: - Ctrl + Alt + Enter
DTK BIOS: (Esc)
Gateway 2000: - F1
Hewlett Packard: - F1
IBM:
Older Models - In order to get into the configuration of the IBM setup screen (CMOS) screen you need to hold down both mouse buttons during bootup.
Aptiva - Press F1
IBM PS/2: (Ctrl)(Alt)(Ins) after (Ctrl)(Alt)(Del)
IBM PS/2 with reference partition: - Press Ins during boot
Some PS/2s, such as 75 and 90: - Ctrl Alt ?
Some PS/2s when pointer at top right of screen: - Ctrl + Ins
NEC: - F2
Packard Bell: - F1 or F2
Phoenix BIOS: (F1), (F2), or (Ctrl)(Alt)(Esc)
Phoenix BIOS: - Ctrl Alt S
Phoenix BIOS: - Ctrl S
Phoenix BIOS: - Ctrl Alt Ins
Sharp Laptop 9020: - F2
Sony: (F3) while you are starting the PC, then (F2) or (F1)
Tandon computers: - Hold down the key after turning on power
Tandon: - Ctrl + Shift + Esc
Toshiba Laptops: - Toshiba Utility
Toshiba: - Press Esc during boot
Toshiba, Phoenix, late model PS/1 Value Point and 330s: - Press F1 during boot
Olivetti PC Pro: - Shift Ctrl Alt + Num Pad Del
Miscellaneous PC's: - Ctrl + Esc or Ctrl and Alt and +
Zenith: - Ctrl Alt Ins
не могу войти в биос Ноутбук Compag Armada 1750
