Скачал патчер 4.10 и комплект файлов к нему.
Скачал патчер 4.10 и комплект файлов к нему. Повторил процедуру.
Ниже лог:
BIOS Patcher ver. 4.1.
Found 1Mbit BIOS!
1. New CPU Support : -> fixed.
2. P3-detect error : not needed to be fixed.
3. New Koeffs Support : -> fixed.
4. 32Gb-problem : -> fixed.
5. Some HDD detect-problem : -> fixed.
6. "MB"/"GB" string search : -> fixed.
7. 65Gb-problem (1-st step) : -> fixed.
8. 65Gb-problem (2-nd step) : -> fixed.
9. Error display Freq>999MHz : not needed to be fixed.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: -> fixed.
Write Allocate addinng: not found.
UDMA for "big"-HDD on UDMA33_only_MB fix: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 30.5%
Adding start.tmp 87.5%
(c)2002 apple_rom, www.ROM.by
