ok i just bought that mobo
now i wanna
1. get a usb bracket - which model will work
the connector is with no missing pins
2 get some SDRAM - will 1 side 256 MB module
work - and how to distinguish 1 side from 2 side
modules?
3 get an agp card - FIC recomeds max 16MB
VC because of the power suplly
will 32MB radeon or g400 work
what about radeon 7500 w/ 64MB and active cooling?
TIA
will registered SDRAM work?
I also have it, PCB 1.2
1. I found USB brackets divides at several types. You can get one and compare wires colors with your manual. Beware - there are 2 rows of pins in configs as that:
1234 1234 12345 1234
12345 1234 54321 4321
2. for my MB 256M PC-133 works well (sorry, dont know type)
3. Riva TNT2Pro 32M with active cooling works perfectly. GF4-MX440 DDR 64M - can suddenly hang up in 3D. (dont test intensively, may be if downclock,
power cooler from main power, will work)
thanks iggor
