AP1250M/H - Не мосфет это, потому и не
AP1250M/H - Не мосфет это, потому и не так звонится.
AP1250M/H is a linear regulator designed as a cost-effective solution for active termination of DDR SDRAM. The converting voltage range is from 1.6V to 6V into adesired output voltage, which is adjusted by two external resistors. The current sourcing and sinking capability of the regulator is up to 1.5A/3A while the output voltage within 2%/3%.
Найдено с помощью www.digchip.com
через Find Part to buy : Request For Quote ->1250M
получили название AP1250m
далее гуглем -> ap1250m pdf
словили PDF
