Mobo is not starting or power supply
11 Окт 2008 - 13:37
Сказочник
27403
1742.14
Jega писал(-а):
Mobo is not starting up even on force
Mobo is not starting or power supply is not starting on force?
Jega писал(-а):
On PS_ON there is 0.8V
PS_ON is PWR_ON (PWR_SW) on front panel connector?
Is you measured voltage on PS_ON (power supply) and +5VSB (power supply)?
Epox EP-4PEA9I rev. 2.2
The final result of investigation is: Main cause
Problem is solved: I found Q2 (D408 N-Channel
I didn`t saw any jumpers for USB supply.
+5 V on USB have jumper switch
You are right! It`s pwr_sw on front
