+5 V on USB have jumper switch
11 Окт 2008 - 17:52
Сказочник
27403
1742.14
Jega писал(-а):
The main problem is with +5 on USB-s who have shortcut to null.
+5 V on USB have jumper switch or transistor switch (+5VSB --> USB power <-- +5V)? Fuse is present?
Epox EP-4PEA9I rev. 2.2
The final result of investigation is: Main cause
Problem is solved: I found Q2 (D408 N-Channel
I didn`t saw any jumpers for USB supply.
You are right! It`s pwr_sw on front
Mobo is not starting or power supply
