Hmmm... Your new CPU doesn't want to start? If yes - the first picture is just what you need. Look at row with letters AG in the left and column with 3 in top of it. Their crossing will give you the needed pin. If it works or if you had not bought it yet - you do not need to do this trick 'just in case'.
It is optional, only for those who cannot run new CPUs on old mobos.
