First format an USB flash drive with FAT. It does not need to be bootable.
Download the latest BIOS, and extract all files. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Turn the AA1 off, and verify both battery and AC adapter are plugged in.
Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press it once. The AA1 will now access the files on the flash drive and initiate flashing the BIOS. After a while the power button stops blinking, and the AA1 reboots by itself. Wait patiently.
If it doesn't reboot, but keeps blinking, wait at least a few minutes before turning it off, and try again.
при доскональном соблюдении КАЖДОГО пункта инструкции сбоев не наблюдал(с десяток случаев было, лишь однажды потребовался повтор)
