First off I'm very sorry that I cant speak Russian, I'm from Poland and even had it in school, but it was a long time ago and I forgot almost everything. So again please bear with me and my english (polish eventually).
I'v got almost exactly the same setup
Duron 1800 from 41 weak = superlocked, but modded to mobile, 256KB cache enabled
Asus A7V (I'v got also A7V133 rev 1.04. and MSI 6340).
Duron works on all of those boards and now the weird part.
MSI 6340 1350Hz and MSR change in XP (CPUMSR)= computer hang
A7V and A7V133 jumperfree = multiplier 16x - this is weird
A7V and A7V133 jumper mode = multiplier 15-20x with few missing in between, both boards run happy at 110MHz x20 :]
now the problems, CPUMSR reports starting and current multiplier just the way it is set with jumpers, but the max available multiplier is reported as 11x I cant go lower than 15x with jumpers so this is propably the cause of hanging while changing MSR in XP to something below 11x
Why my duron reports 11x as a maximum multiplier even that only real available multipliers are 15-20x?
is there any newer bios patcher than BP_6_A10 ? the reason I'm asking is that BP_6_A10 has troubles with ASUS bioses (as I saw earlier in this thread), It patches fine, boots fine, displays real multipliers, and then flashes the screen with red and reboots, booting without PS2 keyboard works ok.
also for some strange reason I cant go >120MHz fsb with A7V133 (lowest multiplier = 15x133=~2000 so its not the CPU max, it runs at 2200 fine)
Hi
I cant go lower than 15x with jumpers so this is propably the cause of hanging while changing MSR in XP to something below 11x![:(](http://bios.rom.by/img/smiles/icon_sad.gif)
