попыталса наити инфу об етой виртуализации все что
попыталса наити инфу об етой виртуализации все что я нашел :
Virtual Channel SDRAM, designed by NEC, also contains SRAM caches. But the caches are not really buffers for the sense amps like ESDRAM. VC SDRAM contains 16 virtual channels, or 16 1 KB SRAM caches. While the ESDRAM module takes care of the "caching" internally, the VC SDRAM caches are managed by the chipset. This results in two important consequences. First, VC SDRAM will only work properly when paired with a chipset that supports it. Additionally, the performance of VC SDRAM will depend tremendously on the quality of the chipset's implementation.
VIA Technology has included support for VCM in their Apollo 133 and KX/KT 133 chipsets. If you are in the market for faster SDRAMs, you may want to consider VC SDRAM. While VC SDRAM does not have a high speed core like ESDRAM, NEC's VC SDRAMs are high quality DIMMs which offer a small, but still significant boost (2-5%) to system performance. This is particularly true in the case of CPUs with smaller caches, such as the Celeron II and Duron.
что умеет ета палка:
kingmax.com/product/superram/superram_ddr_lo400.htm
Datasheet
По виртуализации болше ничего не нашел, в мануале мамки тишина, на ВИА саите тоже не нашел(если плохо искал то направте на путъ истинный) w00t
Попробуй руками порегулироватъ настройки в биос-е, ето похоже единственный способ.
p.s. другой 1ГБ модулъ не пробовал устанавливатъ в тоже гнездо? как он себя ведет ?
Настройка памяти на ASRock P4VM800
