Вот SMART
smartctl 5.40 2010-03-16 r3077 [i686-pc-linux-gnu] (local build) Copyright (C) 2002-10 by Bruce Allen, smartmontools.sourceforge.net === START OF INFORMATION SECTION === Model Family: Fujitsu MHSxxxxAT family Device Model: FUJITSU MHS2030AT Serial Number: NLA4T3617VYL Firmware Version: 3005 User Capacity: 30,005,821,440 bytes Device is: In smartctl database [for details use: -P show] ATA Version is: 6 ATA Standard is: ATA/ATAPI-6 T13 1410D revision 3a Local Time is: Fri Jun 4 14:47:08 2010 UTC SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x80) Offline data collection activity was never started. Auto Offline Data Collection: Enabled. Self-test execution status: ( 20) The self-test routine was aborted by the host. Total time to complete Offline data collection: ( 246) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. No General Purpose Logging support. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 42) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 100 100 046 Pre-fail Always - 156106 2 Throughput_Performance 0x0005 100 100 030 Pre-fail Offline - 146 3 Spin_Up_Time 0x0003 100 100 025 Pre-fail Always - 25600 4 Start_Stop_Count 0x0032 090 090 000 Old_age Always - 5801 5 Reallocated_Sector_Ct 0x0033 100 100 024 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 100 100 047 Pre-fail Always - 3305 8 Seek_Time_Performance 0x0005 100 100 019 Pre-fail Offline - 0 9 Power_On_Seconds 0x0032 063 063 000 Old_age Always - 5680h+08m+56s 10 Spin_Retry_Count 0x0013 100 100 020 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 077 077 000 Old_age Always - 3496 192 Emerg_Retract_Cycle_Ct 0x0032 099 099 000 Old_age Always - 161 193 Load_Cycle_Count 0x0032 073 073 000 Old_age Always - 98986 194 Temperature_Celsius 0x0022 100 001 000 Old_age Always - 36 (Lifetime Min/Max 9/77) 195 Hardware_ECC_Recovered 0x001a 100 100 000 Old_age Always - 22258 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Scan_UNC_SectCt 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 200 Write_Error_Count 0x000f 100 100 060 Pre-fail Always - 2798 203 Run_Out_Cancel 0x0002 098 098 000 Old_age Always - 420919443686 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Aborted by host 40% 3419 - # 2 Extended offline Aborted by host 80% 2591 - # 3 Short offline Completed without error 00% 2591 - # 4 Extended offline Aborted by host 80% 2274 - # 5 Short offline Completed without error 00% 2274 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
Вот SMART
