RedBoot(tm) bootstrap and debug environment [ROMRAM]
Non-certified release, version v2_0 - built 15:51:55, Mar 20 2008
Platform: TCAT DICE/VB (ARM7TDMI)
Copyright (C) 2000, 2001, 2002, Red Hat, Inc.
RAM: 0x00000000-0x00800000, 0x00016528-0x007ed000 available
== Executing boot script in 20.000 seconds - enter ^C to abort
RedBoot> fis load dice
RedBoot> go
semID_FlashWriteActive: 0x00000020
написала при подключении к терминалу:
Watchdog Int installed!!!
RedBoot> go
eapInitializeInterface: nbPersistData = 0x000032a0 bytes
StandAloneInitialize: Clock rate is 1
StandAloneInitialize: Clock source Internal
EAP Space: 00002374
* TC Command Line Interface System *
* Copyright 2003-2007 by TC Applied Technologies Ltd. *
* Running Dice JR/Mini 1394 Appl *
* Chip Detected : DICE Mini (TCD2210) *
* Board S/N: 00000871, SDK Ver.: 03.05.02, build 8028 *
* Application Ver.: 00.000 *
* - built on 11:21:48, Feb 25 2010 *
* MIDI is enabled. *
* Target: Focusrite Pro14 *
* Driver: DiceDriver *
* AVS special memory partitions *
* Focusrite Software Version: 1.0a0, Build 1718
>switchThread - started
eDDR_MSG_DISABLE
setADCMutes: Muted
Standalone Routing: LOW Mode
Sample Rate 44100Hz
Locked (Stand: ON, Con: OFF, Stream: OFF)
setADCUnMuteTimer
setADCMutes: On
а что дальше делать?
