System
Manufacturer : System Manufacturer
Model : System Name
Version : System Version
Serial Number : SYS-1234567890
System Chassis
Manufacturer : Chassis Manufacture
Type : Tower
Can be locked : No
Version : Chassis Version
Serial Number : Chassis Serial Number
Asset Tag : Asset-1234567890
Boot-up State : Safe
Power State : Safe
Thermal State : Safe
Mainboard
Manufacturer : ASUSTeK Computer INC.
MP Support : No
Model :
Version : REV 1.xx
Serial Number : xxxxxxxxxxx
System BIOS : 10/10/2003-i440BX-
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 4
Maximum Installable Memory : 1024MB
Bank 1 - DIMM 1 : DIMM Synchronous DRAM 256MB/72
Bank 2 - DIMM 2 : DIMM Synchronous DRAM 256MB/72
Bank 3 - DIMM 3 : DIMM Synchronous DRAM 256MB/72
Bank 4 - DIMM 4 : DIMM Synchronous DRAM 256MB/72
Chipset 1
Model : ASUSTeK Computer Inc 82443BX/ZX 440BX/ZX CPU to PCI Bridge (AGP Implemented)
Bus(es) : ISA AGP PCI USB i2c/SMBus
Front Side Bus Speed : 1x 115MHz (115MHz data rate)
Maximum FSB Speed / Max Memory Speed : 1x 100MHz / 1x 100MHz
Width : 64-bit
IO Queue Depth : 4 request(s)
Logical/Chipset 1 Memory Banks
Bank 0 : 128MB SDRAM 3-3-3CL
Bank 1 : 128MB SDRAM 3-3-3CL
Bank 2 : 128MB SDRAM 3-3-3CL
Bank 3 : 128MB SDRAM 3-3-3CL
Bank 4 : 128MB SDRAM 3-3-3CL
Bank 5 : 128MB SDRAM 3-3-3CL
Bank 6 : 128MB SDRAM 3-3-3CL
Bank 7 : 128MB SDRAM 3-3-3CL
Multiplier : 1/1x
Width : 64-bit
Refresh Rate : 15.60µs
Power Save Mode : No
Fixed Hole Present : No
Memory Module(s)
Memory Module 1 : Micron MT16LSDT3264AG D23AC370 256MB 16x(16Mx8) SDRAM PC100-322-622 (CL3 up to 100MHz) (CL2 up to 83MHz)
Memory Module 3 : Micron MT16LSDT3264AG A3C2B4A0 128MB 16x(8Mx8) SDRAM PC133U-333-542 (CL3 up to 133MHz) (CL2 up to 100MHz)
Memory Module 4 : Micron MT16LSDT3264AG A3C2B49B 128MB 16x(8Mx8) SDRAM PC133U-333-542 (CL3 up to 133MHz) (CL2 up to 100MHz)
Environment Monitor 1
Model : Winbond W83782D SMB
Version : 3.01
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 25.0°C / 77.0°F
CPU Temperature : 54.5°C / 130.1°F
Cooling Device(s)
Auto Fan Speed Control : No
Chassis Fan Speed : 3096rpm
CPU Fan Speed : 1630rpm
Power / Aux Fan Speed : 1731rpm
Voltage Sensor(s)
CPU Voltage : 1.70V
Aux Voltage : 2.56V
+3.3V Voltage : 3.39V
+5V Voltage : 5.05V
+12V Voltage : 12.28V
-12V Voltage : -12.03V
-5V Voltage : -5.20V
AGP Bus(es) on Hub 1
Version : 1.00
Speed : 2x 76MHz (152MHz data rate)
Multiplier : 2/3x
Side Band Enabled : Yes
Aperture Size : 64MB
PCI Bus(es) on Hub 1
Version : 2.10
Number of Bridges : 1
PCI Bus 0 : PCI (1x PCIClk)
LPC Hub Controller 1
Model : Intel Corporation 82371EB/MB PIIX4E/M ISA Bridge
ACPI Power Management Enabled : Yes
Random Number Generator Enabled : No
Multiplier : 1/4x
DMA Multiplier : 1/2x
USB Controller 1
Model : Intel Corporation 82371AB/EB/MB PIIX4/E/M USB Controller
Version : 1.10
UHCI Interface : Yes
Channels : 2
Speed : 48MHz
Legacy Emulation Enabled : No
System SMBus Controller 1
Model : Intel PIIX4 SMBus / compatible
Slave Device Enabled : Yes
Speed : 16kHz
Multiplexor : Asus IO mux
Expansion Slot(s)
PCI 1 : PCI 32-bit +5V +3.3V PME Half-Length Available
PCI 2 : PCI 32-bit +5V +3.3V PME Half-Length Used
PCI 3 : PCI 32-bit +5V +3.3V PME Half-Length Used
PCI 4 : PCI 32-bit +5V +3.3V PME Half-Length Available
PCI 5 : PCI 32-bit +5V +3.3V PME Half-Length Used
AGP : AGP-2x 32-bit +5V +3.3V Half-Length Used
ISA 1 : ISA 16-bit +5V Full-Length
ISA 2 : ISA 16-bit +5V Full-Length
Port Connector
PRIMARY IDE/HDD : None - ATA / None
SECONDARY IDE/HDD : None - ATA / None
FLOPPY : None - Floppy Disk / None
USB1 : USB - None / USB
USB2 : USB - None / USB
PS/2 Keybaord : Keyboard - None / PS/2
PS/2 Mouse : Mouse - None / PS/2
Parallel Port : Parallel Port ECP/EPP - None / DB-25 pin female
Serial Port : Serial Port 16550 - None / DB-9 pin male
Performance Tips
Notice 224 : SMBIOS/DMI information may be inaccurate.
Warning 2508 : All memory slots are full. Upgrading the memory may be difficult or expensive.
Warning 2541 : FSB exceeds Chipset rated speed. Reduce FSB.
Warning 103 : ECC/Parity memory is recommended for servers.
Warning 2523 : Memory bus speed exceeds memory rated speed. Reduce memory bus speed.
Warning 2542 : Memory bus speed exceeds Chipset rated speed. Reduce FSB/memory multiplier.
Warning 2519 : One of the system fans has failed or is spinning too slowly.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Вот по этому списочку можешь приблизительно составить себе представление о том, как много всякого разного добра могло сгореть...
Касательно напряжения питания ядра - почему ж не надо? По отношению к предшествующим моделям, номинал Vcore "Коппермайна" на 15-30% ниже, информации по данному вопросу (да и по переделке тоже) в Инете предостаточно, google в зубы - и в путь
Ну, к примеру, вот это:![wink](http://bios.rom.by/img/smiles/icon_wink.gif)
SiSoftware Sandra
System
Model : System Name
System Chassis
Type : Tower
Can be locked : No
Power State : Safe
Mainboard
MP Support : No
Model :
Version : REV 1.xx
Chipset 1
Width : 64-bit
Multiplier : 1/1x
Width : 64-bit
Memory Module(s)
Version : 3.01
Cooling Device(s)
Voltage Sensor(s)
CPU Voltage : 1.70V
Aux Voltage : 2.56V
+5V Voltage : 5.05V
Version : 1.00
Multiplier : 2/3x
Version : 2.10
Multiplier : 1/4x
USB Controller 1
Version : 1.10
Channels : 2
Speed : 48MHz
Speed : 16kHz
Expansion Slot(s)
Port Connector
Performance Tips
