Вставали и работали - это как? Они, чтоль, предварительно успешно проходили полный тесет в Hot CPU Tester? То, что они работали, кшна хорошо, но стабильности чуток тоже не помешало бы.
Собссно, на чем тебе и отвечаю:
SiSoftware Sandra
Processor
Model : Intel(R) Celeron(TM) CPU 1400MHz
Co-Processor (FPU) : Built-in
Speed : 1.74GHz
Performance Rating : PR2084 (estimated)
Type : Standard
Package : FC-PPGA Socket370
Rated Speed/FSB : 1400MHz / 1x 100MHz
Multiplier : 14/1x
Generation : 6 (6x86)
Name : P6T (Tualatin) Celeron 1-1.4GHz 1.5V
Revision/Stepping : B / 4 (1)
Stepping Mask : B1
Microcode : MU06B401
Core Voltage Rating : 1.500V
Maximum Physical / Virtual Addressing : 36-bit / 32-bit
Environment Monitor 1
Model : Winbond W83782D SMB
Version : 3.01
Mainboard Specific Support : No
Power Rating(s)
CPU Core Power : 64W (estimated)
CPU Cooling System Thermal Resistance : 0.45C/W (estimated)
Sensors
CPU Temperature : 53.5°C / 128.3°F
Auto Fan Speed Control : No
CPU Fan Speed : 1563rpm
CPU Voltage : 1.76V
Features
FPU - Co-Processor Built-in : Yes
VME - Virtual Mode Extensions : Yes
DE - Debugging Extension : Yes
PSE - Page Size Extension : Yes
TSC - Time Stamp Counter : Yes
MSR - Model Specific Registers : Yes
PAE - Physical Address Extension : Yes
MCE - Machine Check Exception : Yes
CX8 - Compare & Exchange Instruction : Yes
APIC - Local APIC Built-in : No
SEP - Fast System Call : Yes
MTRR - Memory Type Range Registers : Yes
PGE - Page Global Enable : Yes
MCA - Machine Check Architecture : Yes
PAT - Page Attribute Table : Yes
PSE36 - 36-bit Page Size Extension : Yes
PSN - Unique Serial Number : No
CLF - Cache Line Flush Support : No
DS - Debug Trace & EMON Store : No
ACPI - Software Clock Control : No
MMX Technology : Yes
FXSR - Fast Float Save & Restore : Yes
SSE Technology : Yes
SSE2 Technology : No
SS - Self Snoop : No
HTT - Hyper-Threading Technology : No
TM - Thermal Monitor : No
SBF - Signal Break on FERR : No
SSE3 Technology : No
MON - Monitor/MWait : No
DSCPL - CPL qualified Debug Store : No
TM2 - Thermal Monitor 2 : No
EST - Enhanced SpeedStep Technology : No
CID - Context ID : No
DAZ - Denormals Are Zero : No
Advanced Settings
L2 Cacheable Range : 64GB
L2 Cache Grouping : 1 bank(s)
L2 Cache Latency : 1 clock(s)
Data Error Checking : Yes
Low Power Mode : Yes
Fast Strings : Yes
IO Queue Depth : 8 request(s)Остальное опускаю за ненадобностью. Конкретно этот экземпляр (и еще два других) в этом режиме прошел HotCPU в течение 10ти часов...
Мне самому было сначала сложно поверить в то, что старшие модели так хорошо гонятся, однако, жизнь нелинейна...
PS: PCI=31MHz, память, как сам понимаешь, в синхроне...
Processor
Speed : 1.74GHz
Type : Standard
Multiplier : 14/1x
Stepping Mask : B1
Processor Cache(s)
Internal Data Cache : 16kB Synchronous Write-Thru (4-way sectored, 32 byte line size)
Internal Instruction Cache : 16kB Synchronous Write-Back (4-way, 32 byte line size)
L2 On-board Cache : 256kB ECC Synchronous ATC (8-way, 32 byte line size)
L2 Cache Multiplier : 1/1x (1737MHz)
Upgradeability
Socket/Slot : PGA 370
Upgrade Interface : LIF Socket
Supported Speed(s) : 1.74GHz+
Version : 3.01
Power Rating(s)
Sensors
CPU Voltage : 1.76V
Features
Advanced Settings
Fast Strings : Yes
