Собрался патчить биос.
Всё нормально в инфе? --
BIOS Patcher ver. 4.1.
Found 2Mbit BIOS (4.5x)!
Warning - ASUS BIOS!
1. New CPU Support : not found.
2. P3-detect error : not found.
3. New Koeffs Support :> -> fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : found, but more than one result!
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
14.Set "Y" as default on exit: not found.
change_lo_not_found!
UDMA for "big"-HDD on UDMA33_only_MB fix: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 18.6%
Adding cpucode.bin 50.7%
Warning! BootBlock was changed! Flashing BIOS only WITH BootBlock!
Warning - ASUS BIOS!![;)](http://bios.rom.by/img/smiles/icon_wink.gif)
Можно продолжать?
