Вот
Вот
flashrom v0.9.6.1-r1705 on MS-DOS 7 (i786)
flashrom was built with libpci 3.1.5, GCC 4.4.4, little endian
Command line (5 args): c:/flashrom.exe -p internal -o Log.txt -V
Calibrating delay loop... OS timer resolution is 60000 usecs, 1192M loops per second, 10 myus = 0 us, 100 myus = 0 us, 1000 myus = 0 us, 10000 myus = 0 us, 240000 myus = 270000 us, OK.
Initializing internal programmer
No coreboot table found.
DMI string system-manufacturer: ""
DMI string system-product-name: ""
DMI string system-version: ""
DMI string baseboard-manufacturer: ""
DMI string baseboard-product-name: ""
DMI string baseboard-version: ""
DMI string chassis-type: ""
DMI chassis-type is not specific enough.
Found ITE Super I/O, ID 0x8716 on port 0x2e
WARNING! You may be running flashrom on an unsupported laptop. We could
not detect this for sure because your vendor has not setup the SMBIOS
tables correctly. You can enforce execution by adding
'-p internal:laptop=this_is_not_a_laptop' to the command line, but
please read the following warning if you are not sure.
Laptops, notebooks and netbooks are difficult to support and we
recommend to use the vendor flashing utility. The embedded controller
(EC) in these machines often interacts badly with flashing.
See the manpage and flashrom.org/Laptops for details.
If flash is shared with the EC, erase is guaranteed to brick your laptop
and write may brick your laptop.
Read and probe may irritate your EC and cause fan failure, backlight
failure and sudden poweroff.
You have been warned.
Aborting.
Error: Programmer initialization failed.
Универсальная утилита для чтения/записи flash-чипов - [flashrom]
  • в софте-то как раз и
  • под винду Darmawan Salihun порт делает :) И с
  • Да ну вас - нафиг нужно? Разве
  • Под винду-то когда версия будет?
  • С удовольствием буду активным тестером по EzoFlash'у. Вналичии
  • разумеется !
  • Ok. Посмотрим. Но тестирование с вас :)
  • Вот это чудо могете добавить? Я
  • Обновил - новая версия. Добалены несколько чипов Nuovoton, несколько
  • Теперь никаких зависимостей у flashrom.exe нет - только
  • Исправлено много ошибок, почищен код, добавлено новое оборудование,
  • присылайте образец вот этому человеку - http://www.coreboot.org/User:Hailfinger и будет
  • Ему бы еще поддержку какого-то параллельного программатора
  • А можно его как-нибудь вбок закрепить - все
  • а, я просто подумал что вы говорите о
  • Файлы с расширением .zip для меня архивы, думаю
  • это не архив - он самый обычный исполняемый
  • Архив тот распаковывать надо и куда?
  • Обновил ссылки и приклепленные яайлы на самые последние
  • ок. учтем
  • Ага. Совет - отрезайте дебагинфо перед выкладкой. И
  • вышла просто версия 1027 - обновил ссылку и
  • Однако, Object not found! - Error 404...
  • http://wiki.fdos.org/Installation/BootDiskCreateUSB вот инструкции под все ситемы
  • А как ее сделать? Есть ide flash module
  • Max, юзай флэшку загрузочную..
  • Еще zip в придачу, что же пару
  • windows - версии которые приведены выше - все
  • http://khepri.coresystems.de/~idwer/flashrom/r1025/ вот ссылка для DOS версии
  • И что делать с этой кучей непонятных
  • Rom http://www.flashrom.org/Flashrom => Downloads
  • не нашел.
  • Rom в Wiki есть ссылка на windows-версию.
  • Я так и не нашел где скачать инсталяху
