стр.7 даташита
FS_DIS
This pin be allowed to adjust the switching frequency.
Connect a resistor from FS_DIS pin to the ground to
increase the switching frequency. This pin also provides
shutdown function, use an open drain logic signal to
pull this pin low to disable both outputs, leave open to
enable both outputs.
стр.7 даташита
FS_DIS
